I am getting following error when I am trying to add folder from connected device.
Connection error:
Syncthing seems to be experiencing a problem processing your request. Please refresh the page or restart syncthing if the problem exists.
Can you give more information about when/where you actually get which errors (you mentioned one in the title, another in the text). Screenshot(s) and logs will help.
Same problem here.
4 systems use syncthing (windows and linux)
All on auto-update to latest rc version. (0.14.51-rc.2)
Several folders synced, all ok.
Wanted to add another and got this error.
Blockquote
Filesystem Watcher Errors
For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can’t.
buh1-docs FindFirstFile \?\E:: Syntax error in filename, volume or volume label.
