Hey there,
today I added a new fresh windows7 machine, and immediately used the win x64 zip from current 0.14.35
this fresh machine, became paired with the rest of the pack, for one object = folder.
name is for example PPB
the linux machine that originally started sharing this PPB folder like maybe a year or two ago, suddenly showed a box on its syncthing webinterface that the folder patch is nonexistant (on the left side of the gui)
in the details PPB folder suddenly is supposed to be in /home/username/PPB but it never was there, ever it is (physically on disk at for example /srv/raid/path/name/here/PPB
I shut down syncthing on the linux machine.
the config.xml file and(?) config.xml.v20 ? newer version? new structure? migration of config.xml file to some new data structure? are from right a few minutes ago.
why did this folder path change inside the xml file?
i think the .v20 file still has the correct PPB folder path entry, but the .xml file without the .v20 has the bad one showing to /home/username/PPB
what the heck happened? serious bug with syncthing when adding new devices?
sorry for the messy typing but I am in a serious mess and trouble here :((
can I just edit the config.xml or whatever holds the faulty path to home/PPB and revert that path/markup tag back to the correct path /srv/raid/…PPB and just restart syncthing on the linux machine?
thanks for any help. and please debug. thank you.
