hi there.
since I set up my own announcement server on my rpi and changing the udp6 address from [what:ever] to my address (udp6://xyz.abcdef.de:22026) the app crashes every start.
I think the raspberry got no ipv6 address in my datacenter
do I need to install syncthing again or is there another solution?
This is probably a bug, file an issue here.
Also note that the syncthing-android app does not resolve DNS addresses at the moment. You need to use the ip address. Read this howto to get a log.
Can only be fixed manually if you have a rooted device. If so, use adb shell, cd /data/data/com.nutomic* and edit the config.xml file.
Without root, youāll need to āclear all dataā via the android->apps window or reinstall the app.
btw: if you need some translation for the german playstore entry, I could help. Iām already helping translate the app on transifex, but couldnāt find the strings for the playstoreā¦
