Hey all, me again
We use included ignores to control ignore setting from other computers on the network.
I would like, when I set the sync on new computers,to be able to have default ignores he has to use. For now we need to make him ignore all except the .stignore file we created for him, sync that file, then change his ignore setting again to include it
Is there a proper way to make him instal the sync with ignores correctly set all in one share?
Best,
You can set up default ignore patterns for newly added folders, just as every other option, using the “Edit Folder Defaults” button under Settings. That has to be done on each device though, but only once and then applies to all future folders.
Sounds like what you really need is some kind of central management for a cluster of Syncthing nodes?
