Connection via VPN/WiFi not working until reset
Hello,
My current setup is: Server: TrueNas Scale 24.04 Dragonfish Syncthing: v1.27.12
I successfully set up everything - folder, Android device, etc., I can see the sync working with my Android device, and I can see it connected. When I change to a mobile data connection on Android and connect to WireGuard setup to access my local network, the connection between my TrueNas server and Android phone does not happen until I manually restart Syncthing from Syncthing GUI on the server.
When I restart the Syncthing, the Device address changes to the new one. After that when I disconnect to my home network, the connection does not work until I restart the Syncthing via GUI.
Same happens when I change the 2.4GHz and 5GHz as the IP address of my phone changes.
I have tried to set the device address to dynamic, naming all 3 IPs assigned to my phone.
The only change in the settings of Syncthing is the admin login credentials. Local and Global discovery is enabled.
Is there any setting that I can change to get it running on all 3 IPs?
Thank you!
