I have a remote server. I can ssh to it.
It seems to have no UPnP:
[36CSZ] 21:56:09 INFO: No UPnP IGD device found, no port mapping created (read udp4 0.0.0.0:60756: i/o timeout)
I add nodes on both local and remote server, but both of them display each other in Disconnect status.
I’ve use telnet remote_server 20000, and it seems that I can’t reach that port on my localhost.
I think I should use SSH to forward remote port to my localhost. The problem is, I don’t know what to do after forwarding remote 20000 port to local.
I’m not sure what it this? The server is a workstation on our department. I have a account on it, and I can ssh to it. I have no root permission, however.
It has fixed IP, and it also has a domain name point to that ip.
Then i would use this to add the node on your local machine.
So you are in the same sub net?
And the workstation is not behind a NAT router and you are not behind a NAT router? Then you didn’t need any port forward.
