I tried to do an update using the post to system/config - I read the config from the get system/config and post it back as the json body in the post - and if FAILED - boolean is an int in the go language - how can this be correct? I am using 1.4.0 of syncthing - has this been fixed in a later release?
Sorry, it’s not clear what you are asking. Boolean is a boolean in go, it doesn’t magically turn to int in json.
You should start off by providing the error message you are seeing and the config you are posting back.
Never mind - another developer switched a data type without my knowing - thankfully beyond compare works well for this
