Cascade Delete Question ON Resetup
I have been using Syncthing for several years and when I first started using it I saw something that explained that cascade deletes are something to watch out for.
Since then I have only really setup new machines and fresh setups, until recently.
I have one machine that had some issues. Long story short I am now sitting with all the data folders but a fresh default syncthing config/install.
My Question
Are there any risks adding a folder from my central network Syncthing device and pointing the local to the existing folder that should have all the same content so as to avoid a long network re-sync?
And does it matter/change things if the original .stfolder exist?
Thanks.
That’s exactly what you can do, however I would suggest setting the folder type to Receive Only initially, just to be extra safe.
Thank you, it worked exactly as expected. With no data loss.
There is never a circumstance where you should be creating .stfolder by hand.
It’s safer to remove the folder and re-add it back (and let syncthing create it) than it is to create that file by hand.
