Hello , i am new with sync trayzor i found this great software when i was working and i am eager to used this
So Here is my Goal
[+] i want to Create a Server That could send updated patch files on remote location as an example
Here is my setup configuration
[+] on Server side i created a folder called minecraft
[+] Folder Label : D:\Online games\Minecraft
[+] Folder Path : D:\Online games\Minecraft
[+] no file versioning
[+] default ignore patterns blank
[+] folder type send only
[+] Sharing enabled to pc3 with password
[+] tcp address tcp:192.168.88.32:22000 - compression metadata only choose by default
on remote side for trial [+] folder that syncs
[+] folder label D:\online games\minecraft path = the same
[+] advance , folder type: received encrypted , uncheck= watch for changes
[+] full rescan interval by default 86400
some of them i didnt change so here is my problem
when ever sync started it creates folder like these from 1-9 and a-z names the size is correct but the content is not exact as i expect it should be the same with the server side
can someone help me i am stuck and upbeat by 4hrs figuring this out please
