Can I run multiple entities on a single machine? If so how do the ports and home dirs etc map themselves and not trample over each other?
I don’t see this documented in detail anywhere? It is referenced as a possibility in the FAQ with a remark to lookup the config file docs, but I see no actual reference to it in the config file docs?
Can somebody summarise or lay out the required changes. please?
