I have 3 devices. And I want to find the best way to sync up these devices regularly with the lowest overhead.
Now I have one central device which recognizes 2 other devices. Those 2 other devices recognizes this pseudo central server. So these 2 additional devices do not see eachother, they are not defined as friendly nodes to eachother.
Do you feel like actually creating a real 3 node mesh (ie all 3 nodes are friends of eachother) is better than the one I outlined above?
The data will flow along the connections. Currently you have three nodes connected like A <-> B <-> C. If a file is changed on A, the change will be sent to B and then from B to C. If they are all connected, A will most likely send the change to both B and C directly.
The first scenario is better if B has a lot of outgoing bandwidth and the other nodes don’t. But if A has a fast uplink, the second scenario will probably be faster. In either case, things should end up in sync.
