Hi, can you give me a tipp where to find a good free & secure webspace provider. I want to test syncthing there. Thanks!
Syncthing is unfortunately not something that runs on a webspace provider, whatever that exactly is. I do not want a discussion of webspace providers here.
Answering this topic with a link is associated with the risk of being banned for spam.
You will need a VPS. While there are cheap ones, none are free.
You can try play-with-docker. It is not a “webspace provider” but a playground where you can spin as many containers/virtual machines as you like. Each workspace is memory and CPU bounded, and lasts for 4 hours. However, you can open/launch as many workspaces as you want, and as many containers inside each of them. This allows you to test quite complex setups for syncthing.
It is quite similar to a VPS, as @canton7 suggested, but this is free because it is not meant to be used 24/7.
