I plan to self-host a discovery server and my expectations were that this way I would avoid my nodes contact the public discovery servers. However, looking at the code, it seems the configured global discovery server is just added to a hardcoded list of public servers.
Any reason this was designed in this way?
From a security & privacy point of view a user should have the option to stay away from the public network.
I might be misinterpreting the code then. However, I only started looking at the code because the Android client 1.17.0 which has a global server configured shows “Announce 3/3” which I interpret as the client is connected to 3 servers out of 3. Where am I wrong?
Also 3/3 means you only have one discovery server. If you want to roll your own setup and have IPv6 connectivity, I would advise to add one entry that is IPv4 only and one IPv6 only (can be done via DNS, so that both records reference the same discovery server). Otherwise your clients will only announce themselves over IPv4 or IPv6, but not both (at least not reliably). If all of your clients don’t have IPv6 at all it probably doesn’t matter.
All clear, thank you both for the quick response. being able to hover over and verify that’s going on is welcome addition. I’m currently waiting for the F-droid repo to update to 1.18. It seems behind the play store.
You can verify that 2 out of three are local discovery by turning off local discovery. After you have disabled local discovery in the settings it should switch to 1/1 (after a few seconds) to indicate that there’s only 1 discovery mechanism left (which is your own server).
For reference, here’s how it looks on my 1.18 machines:
It is possible to use both the inbuild and custom discovery servers. You can simply put "default, <my custom servers here>" into Global Discovery Servers to achieve this.
I just love how configurable syncthing is. Almost anything is possible.
