Is the autoupdate from 0.10.20 to 0.10.21 not working for FreeBSD 64 bit? My other devices (Win 8.1 32 bit, Win 7 64 bit) got it.
(Is there a way to force the update? [A simple restart doesn’t work.])
Edit: Patience was the solution …
Greetings,
Uwe
It should update itself whenever it sees a device with a newer version connect to it…? Perhaps your FreeBSD machine had been hitting Github’s API’s heavily which then started refusing to respond to it?
It could also be that the release was already there but uploading the compiled version was not finished, I also had this once.
I’ve hit this enough to open an issue: https://github.com/syncthing/syncthing/issues/1285
