Autostart on OpenELEC using systemd
Hello there! I am using a RaspberryPi with OpenELEC on it as a MediaCenter, have BTSync already running on on it, and thought about setting up syncthing for experimental purposes. Downloading, starting, connecting and syncing Files from the attached NAS: worked fine. Autostarting syncthing on boot: not as simple as I expected
OpenELEC has a autostart.sh, but due to the fact I was unable to daemonize syncthing on OpenELEC, I switched to systemd using the provided file [“etc/linux-systemd/system”][1]. I got a lot of syncthing[700]: 13:10:05 FATAL: mkdir ": read-only file system errors, and tried every possible combination of different parameters and settings within those files (searching the web did not really help) so I switched to the provided file [“etc/linux-systemd/user”][2]. That got me the error syncthing[862]: 13:38:21 FATAL: home: No home directory found - set $HOME (or the platform equivalent). although i added the parameter -home="/storage/.config/syncthing" (which is the default config-path) So i googled how to add environment variables to systemd-scripts and edited my syncthing.services file to
[Unit]
Description=Syncthing - Open Source Continuous File Synchronization
Documentation=https://github.com/syncthing/syncthing/wiki
After=network.target
[Service]
Environment="HOME=/storage/.config/syncthing"
ExecStart=/storage/syncthing/syncthing -home=/storage/.config/syncthing
Restart=on-failure
RestartPreventExitStatus=1
SuccessExitStatus=2
RestartForceExitStatus=3 4
[Install]
WantedBy=default.target
Removing either the Environment-Variable or the -home-Parameter results in syncthing not starting. Well, this works for me, but I find it kind of strange to have to provide the home-Path twice, so is this an error or expected behavior? (And I felt like posting this somewhere, so other users trying to get syncthing autostarting on OpenELEC can read it :blush:) [1]: https://github.com/syncthing/syncthing/blob/master/etc/linux-systemd/system/syncthing@.service [2]: https://github.com/syncthing/syncthing/blob/master/etc/linux-systemd/user/syncthing.service
Thanks for this it was very useful!
A while later I found another solution which might be handy for those who simply want OpenElec to run things at start-up including Syncthing, and don’t need daemonised processes:
From - http://wiki.openelec.tv/index.php?title=Autostart.sh
autostart.sh is run on system startup. It can be used to run commands before XBMC/Kodi starts. To create it simply use nano
nano /storage/.config/autostart.sh
So for my Syncthing setup the autostart.sh looked like this on OpenElec:
 /storage/syncthing-linux-arm-v0.11.8/syncthing;
I also added another line to have the autostart.sh make a text file telling me how much free space was left on the remote drives, and use Syncthing to sync it to my local folder:
 sleep 30; df -h | grep /dev/sd > /var/media/[your-Sync-Folder-here]/freespace.txt
The sleep is necessary to let OpenElec mount the drive before putting the text file into it.
Hope it’s useful to someone :slight_smile:
Thanks this is a great tip! Until OSMC comes out as alternative for OpenElec, I am stuck with OpenElec so I was looking for a solution like this.
Unfortunately for me, it does not want to start Syncthing, “Permission denied”. I am on OpenElec 5.0.8 and try to use Syncthing for the first time. I login as root via SSH, I do not understand why I get this message.
My autostart.sh:
#!/bin/sh
sleep 2
mkdir /media/esata
mount -O move /media/mydrivelabel /media/esata
/storage/syncthing/syncthing;
I have a Cubox-i4 Pro and a eSATA HDD connected to it. All my media is expected by Kodi to be on /media/esata/ so I need those first two commands to make sure my HDD is mapped to that path. But those commands don’t affect yours as this is the output when I run the script:
CuboxTV:/ # /storage/.config/autostart.sh: line 7: /storage/syncthing/syncthing: Permission denied
How can I run Syncthing succesfully?
====== SOLVED:
CuboxTV:~ # cd /storage/syncthing
CuboxTV:~/syncthing # chmod +x syncthing
and a note for others and myself in the future:
nano /storage/.config/syncthing/config.xml
Final steps:
  1. Modify 127.0.0.1 to 0.0.0.0 to be able to access the webUI on other systems.
  2. Go to the webui, Settings and set a username and password with HTTPS checked.
Is /storage/syncthing/syncthing marked as executable?
that was the mistake, I updated my post :slight_smile:
Hi there I found this forum while searching for a solution to run btsync on my raspberry i´m stuck afer
nano /etc/apt/sources.list.d/btsync.list past following lines: deb http://debian.yeasoft.net/btsync wheezy main contrib non-free deb-src http://debian.yeasoft.net/btsync wheezy main contrib non-free
while following this tutorial
I really don´t have a clue about how to set up btsync due openelec hasn’t activate apr-get command so any help would be very highly appreciated!
obviously I´m a complete newbie…
Thank you very much for any support and help
regards!
@rubbo this is the forum for Syncthing not BTSync :wink:
Holy MOther of God…sorry about that… after googleing I found the very first post and I saw a light of hope…
keep searching
Thanks!
Why don’t you switch to Syncthing on your Raspberry?
Don’t forget to set a username and password. Please add this to your notes, thx
