Automatic Upgrade: open /usr/syncthingXXXXXXXXX: read-only file system (where XXXXXXXXX is a random number that is generated every time this message comes up)
Because the last 9 digits of the directory where they want the upgrade to be performed changes, I cant figure out what to give permissions for.
My user that I run Syncthing under is STUser. The above directory is owned by root root. The STUser is an administrator user.
You should either switch to the apt repository if you’re on a Debian based distro or relocate your binary into a folder which has write permissions for the STuser.
not sure how to get on an apt repository, but I will look for where the syncthing binary is located and make sure there are correct permissions for that folder. I am not sure that will help with the upgrade message saying that it can’t upgrade to the /usr/bin directory. can you shed any light on that?
