I wanted to play around with changing the icons and other branding withing the app. I made an exact duplicate of the assets folder with files of the exact dimensions and types. I then replaced the stock assets folder with my assets folder and performed the build. All of the regular assets showed up in the build and mine were not used. Can you tell me the following:
during the build are all of the assets pulled down from somewhere (Github?) before the build?
is there a direction to go in when wanting to change the look and feel of the branding side.
finally is there a resource with all of the go run build.go options?
thanks for your help, I have a project and am really excited to be able to work on this.
thanks again
Rob
