I have three systems synchronising using syncthing. All three systems are set up to synchronise with the other two. Thus a file change can propagate from one system to another by two routes.
Are there any known issues/problems with this sort of setup? Should I actually make one system a ‘master’ system and only link the other two systems to the ‘master’ and not to each other?
I’ve got the occasional sync-conflict file appearing and wondered whether it might be due to the three-way sync. If it isn’t this then it’s probably down to the same file getting changed in two places at very close times.
