I’m guessing I know the answer to this question but wanted to make sure.
Would there be problems if the Syncthing folder is within the folder share that is synced to other devices?
I have 3 separate Syncthing folders (1 for each device) so they are not all running the same instance, but I do like to sync the folders to the other device so syncthing is backed up with the rest of data.
