Good day everyone,
I have, as can be read in my other post, some issues with the GUI and want to move to the API to use this to add pending folders and devices etc. However, I am at a total loss on how I’m supposed to do this.
For example, I have a folder pending on a device, and I can see it under pending folder when doing the following GET-call:
https://SYNCTHING:8384/rest/config/devices/DEVICE-ID
However, if I try to do the following GET-call, I only get a 404:
https://SYNCTHING:8384/rest/config/folders/PENDING_FOLDER_ID
Now, everywhere I read regarding the API, it says to send pretty much the same info as a GET-call, but instead use POST/PUT/PATCH, however since I get a 404, it is incredibly hard to understand how I should go on about adding the folder to “syncing folders” instead of pending folders.
The same goes for adding a pending device to the list of active devices.
Basically what I want to do is the following:
Add device, change IP to tcp://X.X.X.X:22000, change Name/Label to the name I want for the device.
After this, I want to do:
Add pending folders, change Label and Path to whatever they should be and change “Minimum disk free” to 10GB as well as on some folders change Send/Receive to e.g. Send Only or Receive only.
Can someone help me understanding the API or point me somewhere where there are a tutorial or whatever to how the API should be used, as I can’t grasp it really from the official docs.
Thanks in advance
