josh4trunks
(Josh4trunks)
September 17, 2014, 4:20pm
25
I’m trying to update the FreeBSD port and make it work with build.go
I’m trying to avoid using git because I want to just get the tar.gz of the source for checksum verification.
my issue is ‘git describe’ is failing because it isn’t a got repo, just the untared source code.
is there a way for my to specify the version being compiled by a flag? or any other way? my other solution is to patch the build script to hardset the version number, but this isn’t as maintainable.
thanks
Nutomic
(Felix Ableitner)
September 20, 2014, 3:19pm
27
l33tname
(l33tname)
September 26, 2014, 12:35pm
28
Is it right that there is no way to build it without mercurial, since go get need mercurial?
calmh
(Jakob Borg)
September 26, 2014, 1:54pm
29
No, you don’t, actually. As long as you use Godep and the bundled dependencies. (I just uninstalled hg from the build server, and it builds just fine.)
bboerner
(Brendan Boerner)
October 13, 2014, 6:58am
30
I began having problems building this evening after taking an update. I did a clean, no luck. Removed all source and refetched, no luck. Any thoughts?
GOPATH=/mnt/home/bboerner/play/go/src/github.com/syncthing/syncthing/Godeps/_workspace:/home/bboerner/play/go
go install -v -ldflags -w -X main.Version v0.10.1+1-gfc6b2d9 -X main.BuildStamp 1413118476 -X main.BuildUser bboerner -X main.BuildHost care -X main.BuildEnv default ./cmd/...
github.com/syncthing/syncthing/cmd/stindex
github.com/syncthing/syncthing/internal/model
# github.com/syncthing/syncthing/cmd/stindex
/home/bboerner/play/go/src/github.com/syncthing/syncthing/cmd/stindex/main.go:26: inconsistent definition for type leveldb.snapshotElement during import
struct { seq uint64; ref int; next *leveldb.snapshotElement; prev *leveldb.snapshotElement } (in "github.com/syncthing/syncthing/internal/files")
struct { seq uint64; ref int; e *list.Element } (in "github.com/syndtr/goleveldb/leveldb")
/home/bboerner/play/go/src/github.com/syncthing/syncthing/cmd/stindex/main.go:26: inconsistent definition for type leveldb.DB during import
struct { seq uint64; s *leveldb.session; memMu sync.RWMutex; memPool chan *memdb.DB; mem *leveldb.memDB; frozenMem *leveldb.memDB; journal *journal.Writer; journalWriter storage.Writer; journalFile storage.File; frozenJournalFile storage.File; frozenSeq uint64; snapsMu sync.Mutex; snapsRoot leveldb.snapshotElement; aliveSnaps int32; aliveIters int32; writeC chan *leveldb.Batch; writeMergedC chan bool; writeLockC chan struct {}; writeAckC chan error; journalC chan *leveldb.Batch; journalAckC chan error; tcompCmdC chan leveldb.cCmd; tcompPauseC chan chan<- struct {}; tcompTriggerC chan struct {}; mcompCmdC chan leveldb.cCmd; mcompTriggerC chan struct {}; compErrC chan error; compErrSetC chan error; compStats [7]leveldb.cStats; closeW sync.WaitGroup; closeC chan struct {}; closed uint32; closer io.Closer } (in "github.com/syncthing/syncthing/internal/files")
struct { seq uint64; s *leveldb.session; memMu sync.RWMutex; memPool chan *memdb.DB; mem *leveldb.memDB; frozenMem *leveldb.memDB; journal *journal.Writer; journalWriter storage.Writer; journalFile storage.File; frozenJournalFile storage.File; frozenSeq uint64; snapsMu sync.Mutex; snapsList *list.List; aliveSnaps int32; aliveIters int32; writeC chan *leveldb.Batch; writeMergedC chan bool; writeLockC chan struct {}; writeAckC chan error; journalC chan *leveldb.Batch; journalAckC chan error; tcompCmdC chan leveldb.cCmd; tcompPauseC chan chan<- struct {}; tcompTriggerC chan struct {}; mcompCmdC chan leveldb.cCmd; mcompTriggerC chan struct {}; compErrC chan error; compErrSetC chan error; compStats [7]leveldb.cStats; closeW sync.WaitGroup; closeC chan struct {}; closed uint32; closer io.Closer } (in "github.com/syndtr/goleveldb/leveldb")
# github.com/syncthing/syncthing/internal/model
/home/bboerner/play/go/src/github.com/syncthing/syncthing/internal/model/model.go:41: inconsistent definition for type leveldb.snapshotElement during import
struct { seq uint64; ref int; e *list.Element } (in "github.com/syncthing/syncthing/internal/stats")
/home/bboerner/play/go/src/github.com/syncthing/syncthing/internal/model/model.go:41: inconsistent definition for type leveldb.DB during import
struct { seq uint64; s *leveldb.session; memMu sync.RWMutex; memPool chan *memdb.DB; mem *leveldb.memDB; frozenMem *leveldb.memDB; journal *journal.Writer; journalWriter storage.Writer; journalFile storage.File; frozenJournalFile storage.File; frozenSeq uint64; snapsMu sync.Mutex; snapsList *list.List; aliveSnaps int32; aliveIters int32; writeC chan *leveldb.Batch; writeMergedC chan bool; writeLockC chan struct {}; writeAckC chan error; journalC chan *leveldb.Batch; journalAckC chan error; tcompCmdC chan leveldb.cCmd; tcompPauseC chan chan<- struct {}; tcompTriggerC chan struct {}; mcompCmdC chan leveldb.cCmd; mcompTriggerC chan struct {}; compErrC chan error; compErrSetC chan error; compStats [7]leveldb.cStats; closeW sync.WaitGroup; closeC chan struct {}; closed uint32; closer io.Closer } (in "github.com/syncthing/syncthing/internal/stats")
/home/bboerner/play/go/src/github.com/syncthing/syncthing/internal/model/model.go:43: inconsistent definition for type leveldb.snapshotElement during import
/home/bboerner/play/go/src/github.com/syncthing/syncthing/internal/model/model.go:43: inconsistent definition for type leveldb.DB during import
exit status 2
exit status 1
I am so upset that this happens, and that godeps doesn’t take care of this.
My gocode sometimes rebuilds packages, and if I got the latest checked out on $GOPATH, I get screwed over by pkg not having the right version.
calmh
(Jakob Borg)
October 13, 2014, 12:12pm
33
This is an annoyance in the compiler, or rather the go
tool that wraps the compiler. We build with a split $GOPATH
; the dependencies under Godeps/_workspace
are first in the path, and the “regular” path follows, something like
GOPATH=/Users/jb/src/github.com/syncthing/syncthing/Godeps/_workspace:/Users/jb
Thing is though, if you run (for example) go get github.com/syndtr/goleveldb
from a terminal with just the regular GOPATH, it’ll build that package and stash it in (on my setup) /Users/jb/pkg
. When you next clean and build syncthing, it’ll check for an existing compiled package of leveldb first in .../Godeps/_workspace/pkg
(which won’t exist), then in /Users/jb/pkg
(which does exist), and use the latter if those files are not older than the source files in the syncthing repo. Hence, possible mismatch.
On the other hand, this is just a sign of other breakage that would have happened had we not been using godeps; because then it would have compiled and built against the wrong version of goleveldb (or another dependency).
Running godep restore
should check out the “syncthing versions” of all dependencies in your regular GOPATH, preventing this from happening. If you want that, and don’t have other things that depend on specific versions of them, etc etc.
This has mostly come up with goleveldb because that API has changed a bit lately… If the external API doesn’t change, this isn’t an issue.
bboerner
(Brendan Boerner)
October 13, 2014, 4:59pm
34
@calmh , thanks for the fix and description of why it happens.
Regards.
aral
(Aral Balkan)
October 28, 2014, 12:57pm
35
If you want to rebuild just the Web UI and test it in Pulse, run:
go run build.go assets
go run build.go
If you want to quickly iterate without rebuilding, just run a quick web server in gui/
— e.g.,
python -m SimpleHTTPServer 8000
calmh
(Jakob Borg)
October 28, 2014, 1:57pm
36
Or just STGUIASSETS=path/to/gui syncthing
calmh:
Or just STGUIASSETS=path/to/gui syncthing.
Last time I’ve checked, that didn’t work for all the files.
calmh:
It should? File a bug!
One a day, keeps the milestone achievement away.
aral
(Aral Balkan)
October 28, 2014, 8:25pm
40
Sorry if this is a newbie question: how do I rebuild all the binaries we have available for download? (I’m successfully building single binaries using the instructions here but would like to build, for example, a Linux binary also from my Mac.) Is there a build task I’m overlooking or a different process for that? Please feel free to point me at something I can read on the subject; tried searching but came up empty. Thanks!
cebe
(Cebe)
October 31, 2014, 12:18am
41
calmh
(Jakob Borg)
October 31, 2014, 6:23am
42
Right, so the short answer is ./build.sh all
after setting up Go for cross compilation . That’s a shortcut for a while bunch of
go run build.go -goos linux -goarch amd64 tar
go run build.go -goos linux -goarch 386 tar
go run build.go -goos linux -goarch armv5 tar
# ...etc
swills
(Steve Wills)
November 1, 2014, 2:57pm
43
calmh:
go run build.go
When I try this, I get:
# ./build.sh all GOPATH is /tmp/t rm -r syncthing rm -r syncthing.exe GOPATH=/tmp/t/src/github.com/syncthing/syncthing/Godeps/_workspace:/tmp/t go build -ldflags -w -X main.Version v0.10.4+6-gb0d95d0 -X main.BuildStamp 1414685405 -X main.BuildUser root -X main.BuildHost jenkinsbuild -X main.BuildEnv default ./cmd/syncthing go build runtime: linux/amd64 must be bootstrapped using make.bash exit status 1 exit status 1
Is there something wrong with my go
install? (I’m building on FreeBSD)
calmh
(Jakob Borg)
November 1, 2014, 3:07pm
44
Yes. You haven’t (successfully) built Go for cross compilation.
